Cetaman
Flight distance : 2494390 ft
Aloha elson,
This is the full page instructions. From what DJI said to you, it looks like you have the GL300B remote controller. Is that what you have?
What you say you did is not what the instructions say to do. You have to press three buttons and one scroll at the same time and then spare one finger (or thumb) to turn on the RC. That is five fingers pressing four buttons and one scroll, but one of the buttons is the power button and you have to press it once and then hold it down to turn on the power. (Remember, it is turned on the same way as turning on the P3 battery.)
So now what buttons and scroll do you press? C1 & C2 are easy and they are on the bottom of the RC. The recording button is the one on the side of the upper left corner of the RC. Turn the RC around and look at it. It has a red dot on it to indicate it is the video recording button. The C1 and recording buttons will be held down with two of your left hand fingers. Your left ring finger will hold down C1 and your left index (or first) finger will press the recording button. Your left thumb will power on the RC as noted (press twice and hold) - after your right hand fingers press their button and scroll. Your right hand fingers will press the C2 button on the bottom of the RC and press the scroll on the side of the right top corner of the RC. Practice pressing the buttons and scroll - but not the power-on button.
Start with the right hand and press the C2 button and the scroll and hold them down. Next, press the two buttons with the left hand and notice how easy it is for your left thumb to reach the power-on button. Practice and just cover the power-on button but do not turn the RC on. Check your fingers to see if you are pressing the right buttons.
When you are comfortable pressing the buttons and scroll and keeping them all pressed at the same time, then it is time to try it all together. Make sure your tablet is on and connected to the RC. The DJI Go app should be installed on your device waiting for you to turn on the RC. Your device should have a rock-solid Internet connection.
While you also keep pressing the other buttons and scroll, press the power-on button twice and hold it down the second time Hold them all down until the four lights at the bottom of the RC have lit up (plus one or two seconds more). This should force the reinstall of the firmware. Look at the System Status screen that gives your flight check status. Does the top line say you need to update? If so, good. Press the line and update. Remember to keep away from any interference. If you have a problem, turn everything off and try again.
Issues on updating the remote controller and corresponding solutions
GL 300A:
Please try to update GL300A remote controllers by using a USB drive/ SD card adapter or connecting the aircraft gimble port with the controller via a USB cable. If you fail updating with these two methods, please connect your controller with your app (meanwhile keep the aircraft off and keep your mobile device connected with the Internet), then turn on your app, go to camera-aircraft status, download and install the firmware and the remote controller will be updated (More than 15 remote controllers in China have been updated in this way).
GL300B:
Remote controllers whose model type is GL300B can only be updated on your app, however, according to the survey, the updates failed in the following three conditions:
First, The remote controller turns off automatically, then the first led light on it turns cyan. And when you connect your remote controller with your mobile device again, the app says no signal, and there’s no notification that says the remote controller needs to be updated.
Solution: It’s possibly because the 1765 module on the remote controller fails updating. So please press these four buttons on the remote controller at the same time, namely, C1, C2, Recording and the Scroll that adjusts ISO, meanwhile, spare another finger to turn the remote controller on (don’t let the other four fingers go), then turn on the app and you’ll be able to download the firmware again and please follow the steps on the app and the remote controller will hence be updated. (More than 10 remote controllers in China have been updated in this way).
Second, the app fails updating the remote controller and the first led light turns red.
Solution: please update on your app again. (More than 2 remote controllers in China have been updated in this way).
Third, the remote controller won’t update any ways.
Solution: the 1.2.0 Android app has this bug that no matter your firmware is latest or not, the app will ask you to update the remote controller. The new DJI GO Android app will solve this bug. (Many more remote controllers in China have been updated in this way).
Hope this Helps! Let me know how it goes. I can still help if you need it.
Aloha and Drone On! |
