quanthonytrang
Flight distance : 419980 ft
The torch method only looks at the X bracing.
There was 4 variants in the shell.
*Flat tabs, no X brace, small vents (old - cracks)
*Flat tabs, X brace, small vents (old - cracks)
*Prong tabs, no X brace, large vents (revised)
*Prong tabs, X brace, large vents (revised)
You need to take the motors off and look at the 4 tabs (you don't need to open up the phantom, just remove 4 hex screws). Now look at the motor mounts, if the tabs looks like prongs (has a notch in it) then then it is the revised shell. If they are 4 flat tab with no notches then its the old shell. Also look at the vents, they should be larger.
