Kneepuck
Flight distance : 275105 ft
Unfortunately, there have been many posts about this problem. It happens on all models of the P3; standard, advanced and pro. It is usually after a firmware update to the latest firmware. Since there has been no official acknowledgement of the issue, it may be a while for a fix. I took matters into my own hands and did an antenna mod and mounted a 5 watt 5.8 ghz amplifier that runs on from 9 - 16 vDC. I use a very lightweight gelcell battey mounted in my homemade ground station to power it. No directional antenna needed, it is fully omnidirectional. I have not yet hit the range limit for the radio controller with this setup. For video reception, you need to keep the rc pointed more or less the direction of the P3, but for control, it works all directions line of sight. about 50 bucks for the amp, another 65 for the battery. I know, you should not have to do this sort of thing on something you just purchased, but until the problem is acknowledged by DJI, if you want to fly and don't want to return it for repair, this is working. For me at least.
