AG0N-Gary
Flight distance : 700846 ft
I had a very small fall from of about 1 meter. It tweaked the shell VERY slightly, just enough you could see about a 1/32 inch bulge at a couple of places in the shell seam. It tore two of the gimbal cables out of their connectors and broke two props. I replaced the gimbal wires and put a new set of props on it. There was no damage to the gimbal itself and it works just like it did before the incident. What I do notice is a slightly different pitch to the motors in hover. I can see a SLIGHT tilt to one motor, and I think that is the cause for a little different sound as it upsets the normal balance of power. It flies fine, camera/gimbal works fine. I just don't like that the motor is canted slightly, and will replace the shell at some point this winter. |
