HDMI Module - Any Luck with Older Updates and Firmware?
1188 10 2015-11-13
BASS 666
right guys my head is melted with this HDMI board not working ... iv sent it back and its been tested so the board is fine ..
my RC and P3A are on 1.1.9 FW and thats the way i want to keep it but the HDMI board doesnt work with old FW apparently ????
so i read that if i had newer FW in the radio the board should work and i tried to update the radio to 1.2.8 using a USB stick for hours to no avail ...
im using the new go app on android 2.4.0 .. does the board work with 2.4.0 ?
why are we told that you can update the RC with a USB stick and it clearly cant be done ?
can anyone help me with this ? are you running old FW and using the HDMI board ?
thanks guys ....
edit ....... i can update the radio using the app but it only gives me the newest FW which is no good to me ....
2015-11-13
Rocket_Aus
Flight distance : 1526929 ft
As soon as you install the board the goapp should of asked you to update the R/C......It will not work on the older R/C firmware from what I understand.
2015-11-13
BASS 666
Rocket_Aus Posted at 2015-11-13 14:53
As soon as you install the board the goapp should of asked you to update the R/C......It will not wo ...
yes that's fine but I don't want to upgrade to the newest FW .. im trying to find out what is the oldest FW the board will work on ....
I will prob have to upgrade everything to the latest FW because I cant upgrade my RC on its own ...
I can upgrade the RC using the app but it would be the latest FW because it doesn't give you a choice ..
I want my RC to be the oldest FW the board will operate on and I want my bird to stay on 1.19 if that's possible ... if I have to upgrade to the latest FW on the bird and the radio then I will just sell my goggles and HDMI board ....
you may be asking why not just update ? my phantom is perfect in every way on the FW I have and I want it to stay that way .. the horror stories iv been reading for months has put me off updating for a very long time ....
2015-11-13
Mad_Angler1
Flight distance : 2741657 ft
What model is your controller
2015-11-13
BASS 666
Mad_Angler1 Posted at 2015-11-13 19:09
gl300a mate..
2015-11-13
Mad_Angler1
it should update then via USB,  have you tried via the gimbal method ?
2015-11-13
BASS 666
Mad_Angler1 Posted at 2015-11-13 19:46
iv tried 3 USB sticks for over 7 hours and I cant try the gimbal method because the FW in the bird is 1.1.9 ..
if I try the gimbal method the bird will update to whatever FW I have on the sd card ....
2015-11-13
Mad_Angler1
BASS 666 Posted at 2015-11-13 19:52
iv tried 3 USB sticks for over 7 hours and I cant try the gimbal method because the FW in the bird ...
what firmware you trying to put on ? 1.28 ?
also is it creating a log file,
i cant remeber if 1.28 has newer rc firmware than 1.1.9, it may not
youwould have to install v 1.320 before you could  update via the app,
Put 1.320 on as that works with V1.9 on the craft fine
2015-11-13
BASS 666
Mad_Angler1 Posted at 2015-11-13 19:56
no log file or flashing lights nothing .. im trying to work my way up the FWs to see what one lets the HDMI board work and hopefully it will be ok with the bird being 1.1.9 FW ...
2015-11-13
Mad_Angler1
BASS 666 Posted at 2015-11-13 20:01
no log file or flashing lights nothing .. im trying to work my way up the FWs to see what one lets ...
1.320 is 100% fine with 1.1.9
Have you unzipped the firmware file after downloading
format the USB memory stick as Dos,
Download the firmware file for your model and unzip, you then place just the .bin file on the memory stick
2015-11-13
BASS 666
Mad_Angler1 Posted at 2015-11-13 20:08
yes mate iv done all that you say to the letter and it doesn't want to play .... I might try and use the micro sd card next in case its an issue with the USB sticks ....
2015-11-13
