Currently being tested; this might be the most advanced mission planner across all existing available apps.
Mix and match waypoint types: standard (the common waypoint you use today), Orbit (a user-defined, 0-360 degree orbit waypoint), 3 Panorama waypoints (planar through 3D) and a focus waypoint that defines a location the Phantom (or Inspire 1) should point towards during the waypoint flight.
Currently being tested but to show you what to expect I've created a short video:
Drag-reorder
Swipe left to delete waypoint
Multi-select and delete
New waypoint types:
Orbit
0-360 degree orbit
Radius
# points
Entry to flight (nearest, north, east, south or west)
Camera point (Towards center, outward from center, face forward (based on entry direction) and face backward (based on entry direction)
Rotation (clockwise and anti-clockwise)
Updates during drag so you can see, in real-time how the relocation affects flight
Region of focus – basically a marker to tell the drone where to face during flight
Any waypoint can be assigned to any focus marker (in any order)
When waypoints are created the current selected focus mark will be assigned to the waypoint
Easy edit a waypoint to change focus mark assignments
Supported by draw flight feature (e.g., select focus marker and draw flight line; flight line waypoints are created and assigned to point to focus mark)
Wow - a far cry from the original P2V+ flight. Looks like you have put a lot of effort and thought into the new features. Nice video. As soon as my new tablet arrives, will investigate. Thanks for the efforts.
Video needs to slow down and include voice explanation. This is especially true when you pull up a menu and make a selection. We have no idea what you are doing, and don't have time to read the text while looking through the menu.
