aburkefl
Flight distance : 78612 ft
Don't have an easy solution to your problem. When the weather was warmer, it was easier to blame problems on your device overheating. Now that temps have cooled off significantly....
As far as flying without the device - once you're flying you *can* fly without your device. As long as there's a controlling signal between your controller and your Phantom, you're fine. You'll be "flying blind" but you can still fly.
Obviously, you will no longer be able to see anything on your device, so you'll have to fly in a totally manual mode, keeping your Phantom close enough to make sure you're not about to run into anything and keep an eye on your orientation in case of an emergency.
You can also take pictures and/or videos after you've lost the connection to your device.
If you lose the control signal, it's a whole new ballgame. If you lose that signal and can't see your Phantom, you better hope your RTH alititude is adequately set for a safe return!
I flew mine "blind" once, mostly as an experiment. A lot less fun!
Art - N4PJ
Leesburg, FL |
