Hi all, I'd like to ask you if you know the thread size of the p3 props cause I still haven't found this spec.
I need this to perform a rough balancing with screws I already have.
Thanks guys.
My prop balancing rod thread diameter is 5.8mm and 25 TPI - bear in mind you will need both left hand and right hand threaded screws. I got my balancing rod from an ebay seller (UK) that I use with my Du-Bro balancer. It's made of aluminium and has a left hand thread at one end and a right hand thread at the other.
