TB47 Batteries - Reduced Capacity
I have a question about two TB47 batteries I am hoping someone can answer.
Two of my TB47 batteries have been charged approximately 20 times each and when I used them to fly with last I had a warning to say that they needed a complete discharge (to 5% or less) on the next charge. This I did and after they were charged it said they were 100% charged but the indicated capacity had dropped from 4500mAh to 4244mAh. The full readings I am getting is the total capacity is 4244mAh, remaining capacity is 4244mAh, charge is 100% and the battery life is 98% for one and 100% for the other. The cells for both are all in balance.
Therefore, my questions are:
- Is this normal and is it safe to fly with them?
- Is there something that can be done to restore the capacity by discharging and charging?
- Are they faulty and need replacing?
I do not want to fly with them until I can confirm it is safe to do so and any advice on this will be gratefully received.
