Adam Gibbs Phot
Good day!
I've had the Inspire Pro x5 for several weeks now and am having some issues getting the bird to go in to travel mode. For some reason I can only get the Inspire to go in to travel mode when I am indoors. Outside I will place the case on a flat surface and then place the copter on the case, using it as my flat, smooth surface, doesn't work. Seeing as I am often in the woods the travel case is about the only solution for a flat surface. I even tried taking the foam out and using the inside of the case as a smooth flat surface. Inside the Inspire seems to have no problem with the case as a flat surface and goes down like a charm. My problem is not so much that the Inspire has problems with getting in to travel mode but not being able to get it back in to the case.
Any thoughts?
Would be great if there was a simple switch or button that doesn't rely on an APP to get the Inspire back to the travel mode. Or a DJI backpack that is actually functional in the outdoors without placing the bird in travel mode.
