damounet
Hello,
i have same problem with dji phantom pro 3. No signal, black screen on app on iPad. Tried to apply old and new firmware. Impossible to go to the end of the installation, always long noise after several minutes.
iOS app 2.4.3, RC 1.5.70, Aircraft 1.6.40
i can take photo and make movies but don't see any image on app "no signal"
thanks for help
Damien
========== 2015.08.13 16:13:41 =====================
Packet: P3X_FW_V01.03.0020.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2015.08.13 17:00:53 =====================
Result: Failed.
========== 2015.08.13 17:19:45 =====================
Packet: P3X_FW_V01.02.0006.bin
Result: Failed.
========== 2015.08.13 17:23:44 =====================
Upgrading ...
Result: Failed.
========== 2015.08.13 17:46:00 =====================
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2015.09.12 11:14:34 =====================
Upgrading ...
Result: Success.
========== 2015.09.12 11:35:00 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.09.28 20:24:43 =====================
Result: Abort.
========== 2015.09.28 20:27:42 =====================
Result: Abort.
Result: Abort.
========== 2015.11.01 15:30:34 =====================
Result: Abort.
========== 2015.11.01 15:48:39 =====================
Result: Abort.
========== 2016.01.03 18:19:05 =====================
Result: Failed.
========== 2016.01.03 18:35:02 =====================
Result: Failed.
========== 2016.01.03 18:43:04 =====================
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3X_FW_V01.06.0040.bin
Upgrading ...
Result: Failed.
========== 2016.01.03 19:24:46 =====================
Result: Failed.
========== 2016.01.03 19:35:29 =====================
Result: Failed.
========== 2016.01.03 19:54:30 =====================
Result: Failed.
========== 2016.01.03 19:58:07 =====================
Result: Failed.
========== 2016.01.03 20:05:07 =====================
Packet: P3X_FW_V01.05.0030.bin
Result: Failed.
========== 2016.01.03 20:13:54 =====================
========== 2016.01.03 20:14:29 =====================
Result: Failed.
Result: Failed.
========== 2016.01.03 20:28:43 =====================
Upgrading ...
Result: Failed.
========== 2016.01.03 23:05:26 =====================
Result: Failed.
Result: Failed.
========== 2016.01.04 07:46:48 =====================
Result: Failed.
========== 2016.01.04 07:48:02 =====================
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
========== 2016.01.05 11:42:17 =====================
Result: Failed.
========== 2016.01.05 11:51:37 =====================
Result: Failed.
========== 2016.01.05 11:56:41 =====================
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Upgrading ...
Result: Failed.
========== 2016.01.05 12:32:15 =====================
Result: Failed.
Upgrading ...
Result: Failed.
========== 2016.01.06 09:06:36 =====================
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
========== 2016.01.07 09:56:50 =====================
Result: Failed.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Upgrading ...
Result: Failed.
grrrrrrrrr
