ghoonk
Flight distance : 394626 ft
United Arab Emirates
The update has just killed my aircraft.
Exactly the same scenario as GB44
As always, I loaded the firmware onto my microSD card (formatted to FAT32), and started the update process.
At the end of the update process, the tone went into a flat beep (similar to the d-d-d-d, but ddddddddddd instead) and the logs showed an error. I tried it again, and the error persisted
I tried to downgrade to v1.4 and still have the error with the same symptoms.
I removed the SD card and formatted it, and inserted it as a blank SD into the aircraft, and there was no error showing up in DJI Go - firmware is correctly listed as 1.5.30 but now there is no video feed.
My aircraft is now unusable, and if any of DJI support staff can help me out, I'd really appreciate it
Result: Success.
========== 2015.08.28 15:27:03 =====================
Packet: WM610_FW_V01.03.00.00.bin
Upgrading ...
Result: Success.
========== 2015.08.28 15:29:11 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.08.28 15:31:04 =====================
Upgrading ...
Result: Success.
========== 2015.08.28 15:33:10 =====================
Result: Abort.
========== 2015.08.28 15:35:38 =====================
Upgrading ...
Result: Success.
========== 2015.08.28 15:37:39 =====================
Result: Abort.
========== 2015.08.28 15:39:00 =====================
Result: Abort.
========== 2015.08.28 15:40:03 =====================
Upgrading ...
Result: Success.
========== 2015.08.28 15:42:10 =====================
========== 2015.08.28 15:42:42 =====================
Upgrading ...
Result: Success.
========== 2015.08.28 15:45:03 =====================
Result: Abort.
========== 2015.08.29 07:03:40 =====================
Result: Abort.
========== 2015.08.29 07:15:38 =====================
Result: Abort.
========== 2015.09.07 21:45:44 =====================
Packet: WM610_FW_V01.04.00.10.bin
Upgrading ...
Result: Success.
========== 2015.09.07 22:06:38 =====================
Result: Abort.
========== 2015.09.11 23:20:49 =====================
Upgrading ...
Result: Success.
========== 2015.09.11 23:28:17 =====================
Result: Abort.
========== 2014.01.01 00:00:03 remo-con disconnect======
Result: Abort.
Upgrading ...
Result: Success.
========== 2015.10.26 20:05:57 =====================
Result: Abort.
========== 2015.10.26 20:13:26 =====================
Result: Abort.
========== 2015.10.26 20:14:15 =====================
Upgrading ...
Result: Success.
========== 2015.10.26 20:19:02 =====================
Upgrading ...
Result: Success.
========== 2015.10.26 20:21:46 =====================
Result: Abort.
========== 2015.10.26 20:24:24 =====================
Upgrading ...
Result: Success.
========== 2015.10.26 20:26:43 =====================
Result: Abort.
========== 2015.12.12 13:13:39 =====================
Packet: WM610_FW_V01.05.00.30.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2015.12.12 14:15:29 =====================
Result: Failed.
========== 2014.01.01 00:00:07 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:06 remo-con disconnect======
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
========== 2015.12.12 14:44:42 =====================
Result: Failed.
========== 2015.12.12 14:50:42 =====================
Upgrading ...
Result: Failed.
========== 2015.12.12 14:53:23 =====================
Upgrading ...
Result: Failed.
========== 2015.12.12 14:56:44 =====================
Upgrading ...
Result: Failed.
========== 2015.12.12 15:38:22 =====================
Result: Failed.
