Switch left/right and yaw controls
9162 8 2014-12-26
dji
Is there a way to program the PV2+ to use the right stick for yaw (and forward/back), and the left stick for left/right (and up/down)?  I have a tremor in my leftf hand, and it would be easier for me to control flight if I could use the right stick for most operations.
2014-12-26
Gerry1124
Yes, the DJI Phantom 2 Vision Assistant_3.6 has mode 1 and 2.  Mode 1 puts the throttle on the right and mode 2 has throttle on the left.   Do you have the new version 3 Phantom with the throttle lock?
2014-12-26
dji
Gerry1124 Posted at 2014-12-27 08:36
Yes, the DJI Phantom 2 Vision Assistant_3.6 has mode 1 and 2.  Mode 1 puts the throttle on the right ...
Thanks,
Yes, I have throttle lock.  But I'm looking to put yaw on the right stick, not throttle.  What I'd like for the right stick is fwd/bck/yaw; left stick is left/right/throttle.
I thought I had latest assistant but don't see "mode" settings -- can you point me to them?
2014-12-26
Gerry1124
dji@drmr.com Posted at 2014-12-27 08:49
Thanks,
Yes, I have throttle lock.  But I'm looking to put yaw on the right stick, not throttle.  ...
You can switch the stick modes but that is all.
Left stick is up/down and spin left/right
right stick is forward/backward,  left/right
2014-12-26
MacCool
Thanks,
You can just switch to Mode 1.
The throttle lock is managed by a white plastic clip that slides into the left stick/gimbal. Open the back, unclip it, and it slide right out. You can pitch it if you don't want the lock, or...I think you can slide it into the right stick so that it will lock in the full down position.
2014-12-26
MacCool
guymacdonald@ip Posted at 2014-12-27 10:50
Quote from 3rd post from the top....
"What I'd like for the right stick is fwd/bck/yaw; left stick ...
Ah. You're looking for Mode 3. Certainly do-able, but you'll need a soldering iron, not software. I'm not aware of any company that sells a compatible transmitter that works in Mode 3.
2014-12-26
dji
guymacdonald@ip Posted at 2014-12-27 10:02
Am I right in thinking you want to......
Pitch Forward and Back with the Right
Yes, that's right
2014-12-26
dji
guymacdonald@ip Posted at 2014-12-27 10:14
These are your options....
I think option 4 is what you are wanting?
Thanks!  This looks promising, will try.
2014-12-26
zavnok
Switzerland
Found the below link to enabe or disable slow pannning  via slower left-right controller mod.
Anyone tried this mod?
http://www.quickinet.net/fly/
DJI Yaw Speed Control Mod
This mod controls the speed of the yaw of your bird in flight. (right / left pivot) The stock setup is very fast. You can control the speed of the yaw with very small inputs to the sticks, but this mod gives you an even finer control over your turns for very nice "cinematic" pans.
2015-1-11
