jpflkeys
Once the P3P was on the ground & the stick was returned to the neutral position it should have powered the props down significantly to a idle speed, such as when you first activate the motors. The idle speed was very high like just before lift off. The only way I could get it to drop to idle speed was to move the stick downward, almost to the stop position, actually it was almost like it was stuck & I had to move the stick back & forth a few times before it slowed the props down. The weird thing was it started to take off slightly by itself & I wasn't even on the stick. Started to throttle up by itself on one side of the P3P. There was no wind either. I have been flying a Blade Chroma & when you land & release the stick it powers down to idle speed & doesn't move. Just trying to get a feel for what's normal for the P3P. I was a bit hesitant purchasing one but the reviews were great but support was terrible. |
