jamescole
Mexico
Hello Guys...
Well what can I say... coming from a P3 this is a very very different machine... Very Exotic indeed, I love it.
Only a few "issues"
1. The arms are a bit wobbly... the quad flies and transforms perfect, no vibrations in the arms or jello on the video as far as I can see, but the arms are a bit loose to the point that they make a clicking sound when they move... they seem to move front and back less than a millimetre.
2. The camera fan did not work at first but I pushed it with a needle and now it works every time... normal?
3. The red dot quick release props have a little play in them unlike the white dot ones which are pretty solid... issue?
4. The gimbal rotates 360 degrees, is there a way I can move it manually without the second controller to yaw? Just like I move it up and down....
5. On the battery voltage meter on the DJI GO app sometimes the voltage goes to "red" level for a bit which I think is below 3.4 volts and then goes back up to "yellow" or "green" voltage readout... all this while having +50% battery remaining... is this normal to fluctuate like this? I get no warnings whatsoever.
So far I am thrilled but would like to clear this issues up...
And to whomever is wondering the FCC ID is still 1014 and T600 label which is wrong thanks DJI!
Thanks!
JC
