A good reason to upgrade to FW 1.6
1356 12 2015-12-23
JcP3A
Curaçao
http://motherboard.vice.com/read ... ed-by-falling-drone
2015-12-23
classicalle
Flight distance : 8903051 ft
Good reason.
2015-12-23
nrgwise
I don't see the relevance at all to new firmware.
2015-12-23
pi-inthesky
Flight distance : 13058 ft
Wheres the relevance to updating wouldnt have change the outcome
2015-12-23
aopisa
Flight distance : 430686 ft
Plus this was not some irresponsible idiot hobbyist. This was a professional drone with a broadcast TV camera. This has nothing to do with firmware, the FAA or Kanye West's concerns whatever that means. I'm not going to look it up because I don't care what Kanye West's opinion is about anything at all.
2015-12-23
Barney Rubbel
??????  Cool video (aside from bad advertising), but what does it have to do with anything about firmware? Hello?
Barney
2015-12-23
JcP3A
Curaçao
What’s New:
1.      In cold environments, propulsion output is automatically adjusted based on battery temperature and cell voltage. Horizontal and vertical speed is also decreased to avoid triggering battery protection.
2015-12-23
Jkeller84
Flight distance : 396955 ft
The new firmware addresses the recent issues of batteries entering protection mode in colder weather (shutting down and falling from the sky). I think that is what he means in the OP
2015-12-23
aburkefl
Flight distance : 78612 ft
aopisa Posted at 2015-12-23 10:23
Plus this was not some irresponsible idiot hobbyist. This was a professional drone with a broadcast  ...
Add my vote to that!
2015-12-23
JcP3A
Curaçao
Jkeller84, exactly what I meant. As usual there are always trolls with a total lack of imagination and pea size brains roaming the forums who don't even read the release notes.
This was a professional drone with TV camera operated by a sports-marketing agency. They had the authorization to flight but with 2 restrictions: do not fly above the track and be a minimum 15m behind the skier. They did not respect it and now drones are totally banned from the event.
The reason of the crash is unknown but it is quite possible to be due to the cold affecting the battery.
The new FW also provides Optimized battery management - regardless of temperature - and even if you do not live in a cold place you should apply the update. DJI do not provides any information on what this optimization is but it could be related to Phantoms crashing when starting with a battery not fully chrged but I would recommend anyone to start with a fully chrged battery.
Jean-Claude
2015-12-23
aopisa
JcP3A Posted at 2015-12-23 18:37
Jkeller84, exactly what I meant. As usual there are always trolls with a total lack of imagination a ...
Hey Bud-
Not a troll here and thank you for assuming that I don't read anything (sounds like trolling to me). I read everything I can, release notes, user manuals cover to cover, etc. I know what the 1.6 upgrade does. I just did not make the connection between a 100+lb. multi-rotor behemoth with a television camera and a little Phantom. Sorry I am so dim.
2015-12-23
toddf.perkins
i don't think I will update yet. So far, I haven't even had to put a jacket on this year yet
2015-12-23
jack1144
How about a clear statement of the connection, which is a  weak one anyway., and way less negative attitudes.
We should all be here to help each other.
aopisa is NOT a troll
2015-12-23
