olpdon
Flight distance : 191109 ft
Just a quick question did you format SD card with Osmo first?
When I downloaded new Bug Fix Bin File on formated SD Card and turned on Osmo (just the Osmo) nothing else on, Osmo reacted similar for me as yours.
The update went rather quick. I was expecting a long update as the first. It only took but a few minutes and it caught me off guard so I really don't recall the number of beep and LEDs there were a few on both as I best recall. Restarted Osmo with the same card in Osmo and went about normal use.
I also have the Osmo handle kit so after all was well with Osmo I transfered Gimble to 2nd handle turned on Osmo it did a very quick update, and all good.
Removed Gimble from handle #2 pulled the original SD card and replaced it with SD card for Video/Photo use.
Question did you use the original DJI SD card? I only use orignal supplied DJI SD Cards on all FW updates only be it Inspire 1, Inspire 1 Pro, ect. And only for the purpose of FW updates.
If you did all the above the same. I am at a loss, other then give it one more try with the above process again. As of today I haven't had the 119+ show up on above.
Or just wait for DJI Tim for a answer..
Hope all works out.
Don
PS Is just bothered me too much that 119+ kept showing up, and the Osmo is more of something that I don't mind having down time on as I would my I1, I1Pro. So the Osmo is more of a lets see if its okay to update FW first and work out problems with. Kind of like a Flight simulator for me.
