Ok, I've had the P3S for a week now. I've beening dying to do a video but the scenery isn't the greatest in Memphis, TN. I went to the largest park in our area, lots of open spaces. I need to learn how to be a little better in the turns and making it smoother but I'm proud to get this first video under my belt. Any and all recommandation are welcomed. I'm a photographer with little to no experience in videography.
Nice work, you appear to have got the knack of getting exposure correct, which is often a failing of new pilots. Perhaps you might purchase a set of ND filters just in case you need them (if you already have not done so). And your colour correction is spot on. If you experiment with the menus in the Go App, you will find you can slow down the control inputs to make gimbal tilt and yaw slower and it will make the camera movements smoother.
your doing a good job.... as far as getting the best flow from the video, I have to tell you that I cheat. I purchased Lichy and use the waypoint mode and auto camera angles. POI and all the toys. takes a little planning up front, but then I just hit the button and enjoy the show.
