jennings
Flight distance : 221414 ft
After testing two different Osmos, I have come to the conclusion that there are some serious issues with the audio system on both Osmos.
I have used a variety of external mics including lavelier, Rode and Sony wireless blutooth microphones.
In nearly every case there are problems with wide dynamic sounds, if you turn down the volume to avoid overloads the quiet passages disappear. The most succesful mic was the Sony bluetooth wireless mic providing you set the output volume to low and the Osmo gain to default.
Other mics gave terrible results with frequent crackles, clicks and distorted sound.
My observations suggest that the audio level meter on the Osmo is unreliable and not a good indicator of actual levels, trying to take footage incar results in some weird electronic clicks and distortion, some good results were had with relatively consistent sounds but louder transient sounds invariably produced huge distortion.
In general the audio design of the Osmo is crap and the designer/engineer sacked.
Hopefully DJI will fix this at no cost to all who have shelled out over A$1000, a pity since the gimbal on video quality is superb. Come on DJI give your customers some support so we can continue to invest in your products.
For now I will revert to my GoPro 4 and gimbal which is not as compact or covenient to use in the field but at leats I get useable sound.
