Hi ive been having some issues with my p3 pro. I was flying in the simulator and when I landed all of the suddon my phantom started doing these really loud beeps. This happened once before when i went to go fly my phantom and it just beeped really loud when i turned it on. everything looks ok in the dji app and when i go to "about" it doesnt show anything. I believe that my problem is that i left the firmware on the SD card. Should i delete the firmware after updating the phantom and the batteries? The first time this happened they came out with a new firmware and i just loaded it into the phantom and turned it on and after about 10 minutes it quit beeping and starting updating normaly. ive also noticed that i have not been able to find the updates through the dji app any more. but any ways its on version 1.6.0040 now and it will not quit beeping. If i check the logs it sais that its trying to update and has the same firmware thats trying to be updated to. I am aware of that but how do i get the beeping to go away without waiting for a new update to come out? ive also seen that people are downgrading and then updating again but i can not seem to find out how to do it. please help!
The firmware is not needed on your SD card after updating.
Post the contents of the text file here if you want us to make sure update went as supposed.
ive also reinstalled the dji app on my ipad and doesnt help. it states ready to fly at the top, shows the aircraft is connected and the controller light is green. also in the "about" section it states that the phantoms firmware is on 1.05.0030 when ive put 1.06.0040 on it and it states that its the current firmware from the sd card. im at a loss of things to try
So it sounds like you and I have the same problems but arrived there by different paths. After many emails with tech support I was advised to get a compatible android device and reinstall update. Well after asking around I was able to hook up with a friend and try it out....well guess what!! Nothing! We tried 2 different Samsung galaxy's with no luck. I'm actively going thru the return process as we speak but this frustrates me to no end so I continue my search for a remedy. Good luck! Cuz the more I search the worse it looks
