LightBridge 1 Air Encoder Not Recognized
800 1 2016-1-16
topsailsailor
Hi,
I have a P2 with a H4-3D, GP4Black, LighrBridge 1.  I am not recieving video after turning on the all the compentents in the recommended order.  I have used the LB without issue for 1 year.
When I connected the air system to the LB Assistant software, only the air system contoller firmware is recognized.  The air system encoder and air system transmitter are blank (not showing latest fireware version).  I have a green control light and red video light on the air transmitter.
Any advice or help?
Many thanks.
C
2016-1-16
jgriffith3
Sounds similar to my problem except I'm getting video but not control and never have and now have a lightbridge sitting int eh box.  I use both the gimbal cable and the mini hdmi cable plugged into gopro otherwise the camera uses its battery instead of the P2 battery, you might try that.  Also although the LB asst. shows the current version it keeps telling me there is an upgrade available .  Any suggestions on my problem?
2016-1-23
