Kneepuck
Flight distance : 275105 ft
Delete the app from your device. Make sure the entire Dji folder is deleted from your device. Restart the device. Re install the Dji-Go app. Turn off the device. Turn on the remote, then the Phantom then the device. Look for the Phantom wifi signal in the wireless settings on your device. Connect to it. It will tell you you need a firmware upgrade. Select to do that. Disconnect your device from the Phantom wifi and connect it to the internet. The update will download to your device. When it is finished, disconnect your device from the internet. Connect to the Phantom wifi signal. Select to proceed with upgrade. Leave the room and close the door behind you. Stay away for about 30 to 45 minutes. After that, come back and your phantom will be upgraded. Be sure to calibrate IMU and compass before flight.
