Osmo - Straight Extension Arm
1790 10 2016-1-24
MsNikita
I'm thinking about buying the Osmo Straight Extension Arm. I'm looking at the images on the product page and getting a little confused.
Can someone who knows about this product clairfy, please which screw fitting it actually comes with?
The first image implies the screw fiting is much longer than the diagram suggests. And I don't need the bike mount right now.
Cheers.
2016-1-24
fran
Flight distance : 74052 ft
it comes with both
2016-1-24
MsNikita
Thanks Fran.
Maybe the webmaster who updates the product page should make this clear!!
2016-1-24
rj74
It also comes with an extra grip plate that you can attach instead of the short screw, then you can mount two arms together with the long screw.
If i'd known this at the time I would have ordered two arms.
2016-1-24
rodAndTheCat
New Zealand
rj74@me.com Posted at 2016-1-25 08:51
It also comes with an extra grip plate that you can attach instead of the short screw, then you can  ...
and they are really good quality too- I have the arm and the accessory extension for mics, lights etc and that is also really nicely made. Be aware that you need both if you want to use the accessory mount, otherwise there is no way to mount your phone as well.
Rod and the cat.{:3_48:}
2016-1-24
kvamens
Norway
rodAndTheCat Posted at 2016-1-24 22:18
and they are really good quality too- I have the arm and the accessory extension for mics, lights  ...
What's best assessories to use if you want to mount Osmo on a normal photo tripod?
Do the screw fit normal photo tripod?
Anyone know?
Thanks
2016-1-25
fran
kvamens Posted at 2016-1-25 09:32
Do the screw fi ...
Im using  DJI OSMO   extension stick , this  connect to a normal tripod and from this you can connect the OSMO.
They may be other alternatives but  this one works fine
2016-1-25
MsNikita
fran Posted at 2016-1-25 11:26
Im using  DJI OSMO   extension stick , this  connect to a normal tripod and from this you can conn ...
I'm wondering, isn't it possible to mount our Osmo to a regular tripod with a ball-head using the straight extension arm too?
2016-1-25
MsNikita
rodAndTheCat Posted at 2016-1-24 21:18
On order, I have a couple batteries,  straight extension arm and a universal mount thing...
I would like to hope DJI will make a more convenient travel charger with the regular US style 2 prong plug that flips in and out? Having an IEC C7 cable is nice but not very travel friendly. :@
Or how about a dual battery charger wilst your in the process? Again with the US style 2 prong plug that flips in and out
2016-1-25
dennismurry08
Flight distance : 5948264 ft
MsNikita Posted at 2016-1-25 04:44
I'm wondering, isn't it possible to mount our Osmo to a regular tripod with a ball-head using the  ...
The sizes are 1/4 20
2016-1-26
MsNikita™
dennismurry08@c Posted at 2016-1-26 21:08
https://www.youtube.com/watch?v=PwY9PacGJeQ
Thanks Denis. I got this working with the extension arm & a ball-head
Still waiting other accessories to appear.
Coming from HK, guess that'll be around February when they arrive.
2016-1-26
