DJI-Adela
2.7.1(2522) is the latest DJI GO App version, don't worry about it.
According your upgrading 'Results', I can tell that you tried to upgrade the firmware version v1.4.1.80 and v1.5.2.0 repeatedly which is not necessary. Please note that the "Result: Abort" implies that the firmware version which you're try to upgrade to is identical to or older than the current firmware in the Osmo, just as stated in the next row of explanation.
If you are using the DJI GO App in the IOS system, after the upgrade of the latest firmware upgrade, open the DJI GO App, connect to the Internet first and then connect to the Osmo WiFi, the FW version showing in the App should be correct.
If you have any other problem, please just leave me message.
Thanks for your support to DJI! |
