Geebax
Yes, you have jello effect in your footage, but also you would make better clips if you slowed down your movements a lot, those rapid tilts and pans are annoying. Also, it is best to tilt the camera down further and not make sudden moves with the aircraft as you are also getting the props in shot and prop shadow as well.
Jello effect is caused by one thing, and one thing alone, vibration in the camera. The first cause to eliminate is vibration caused by the camera gimbal. That can be checked out on the ground or just hovering in the air in front of you. Does the gimbal buzz or vibrate while sitting in one place? If so, the most usual reason is that the small socket screw that holds the gimbal arm onto the gimbal electronics section is loose. It can be tightened using a small Allen key.
As your jello seems to be most noticeable when the aircraft moves forward, I think it is quite likely that you have one or more out-of-balance props. There are several discussion on this forum about how to balance your props and also some good 'howto' items on YouTube.
