DJI-Ken
Flight distance : 1515312 ft
Can you post a video. When you first put the SD card in and power the aircraft you should see the camera move around and make some beeps. After 30 seconds or so it should make 4 beeps in a row DDDD,DDDD,DDDD and the gimbal light should alternate Red/Green and it should do that for up to 25 minutes. Then when updated the gimbal light should be solid green and then 3 beeps in a row D-DD,D-DD,D-DD and so on. Then that means its done.
If it doesn't do that, then post the hidden files on the SD card like I explained earlier to you. |
