pantera989
New Zealand
Hi Beau, there are two settings you can set, Battery warning, and critical battery level. The first will give you an audible and visual warning that the battery is getting low, the second will initiate RTH.
I had the Auto RTH start up on me once when I first got mine, when it happened, a little pop up message came up on the app (android), with an option to cancel it, which then allowed me to land manually.
Edit: You can also change the RTH height level
