pantera989
New Zealand
Anything that can use a GPU to accelerate processing will work, they will all be essentially the same after that. Premiere and Resolve can both utilize the GPU for processing, the later of which is much easier to setup, depending on your card.
The hardware will probably have a much greater effect then the software you use. |
