nigelw
Flight distance : 518084 ft
It shouldn't make any difference because of the way threads work. Even worn & very loose threads will still tighten properly. It's the friction you feel when it finally tightens that holds it together. If the thread in the prop is about to strip, you'll feel it stretch & strip as you tighten it. It simply won't tighten.
If it were holding some kind of flange or joint that's subject to a lot of force then things might be different, but relative to the size of the thread, there isn't much force attempting to strip the threads.
That said, if it bothers you, change it.
