Microcyb
Flight distance : 1095955 ft
Dead66 Posted at 2017-1-31 17:53
So Microcyb,
I got no response on the other thread. But I have learned a lot. I can take the amplifiers off and use just the antenna and get around 2000 or a little more feet out of it before losing HD connection (the GPS and the other radio signal seem to still be connected even when I lose HD....
You should get more range with the Suntans. I use the Argtek with a higher DBI flat panel 5.8 GHZ antenna and my normal RC range is 6000 ft (1828.8M) I have no boosters, but also another trick is to use the MagicPowerv5 to change the channels to get some more distance. With the boosters, I have heard many get over 11,000 ft (3352.8M).
Just remember the FPV uses 2.4 GHZ and that is for your video and instrument readings. The 5.8GHZ is for your RC connection from the controller to your bird.
So even if you lose your FPV you should still be able to fly very far away and still have control such as RTH.
If your booster is plugged into the RC 5.8 GHZ antennea only. This means the if you looked at your RC signal on your Go App, it should still show full bar connection, but you might lose your video link to see where you are flying. This is where the MagicPowerv5 comes into play. It changes the channels like that of the Phantom Pro to give you a longer and better video link.
