AG0N-Gary
Flight distance : 700846 ft
As I understand it, if the battery is fairly full, OR has been allowed to sit for a period at a low level, you probably need to push the button once, and then a second time, holding it until it turns on, just like when you fire it up to fly. When it turns on, plug the charger in. This forces it to charge, even though it may not think it needs it. Personally, if it is pretty full, I'd rather run it down under proper load (running the Phantom), before forcing a charge. It just seems like it would allow the balancing circuit to work better. |
