z5.zonefive
Flight distance : 24298 ft
My P3A did the exact same thing as the OP's the other day after dozens of flights with no issues. It gets connected the same way every time, and the App doesn't start till I plug the tablet into the R/C. (starts automatically) You are totally unable to take the App out of thinking that you have a P3P. I did all sorts of reboots, even tried it with a different phone and still had the same issue. The last thing I tried was with everything still turned on, I shut down the battery, let the P3A shut all the way down, and then turned the battery back on. The App changed and showed me correctly as a P3A, and it flew fine. I have absolutly no idea what happened, or why turning the battery off corrected it but it did.
When I flew it today, it worked as it should, started up and showed the P3A. hopefully it was a one off glitch.
Only difference that I see, is that the Op has an Apple device and I have android K1 tablet and Note 3. Note 3 has latest version of Go app, K1 has prior version. |
