eganders
Flight distance : 191821 ft
is there a way to get the dgi controller to charge the iphone at a rate sufficient to maintain the charge?Alternatively, is there a Y connector that would allow you to put the backup battery on one leg of the Y and the DGI Professional controller on the other?
The DJI Professional uses the iPhone charging port so you can't hook a backup battery to it while you are using the Phantom 3 Professional.
