nigelw
Flight distance : 518084 ft
I think you have to use your own judgement & common sense.
Ask yourself, "am I likely to be in an area where I might collide with another aircraft?" If I fly off a 1000ft cliff from the top of the mountain, but stay within say 100 meters of it, I wouldn't expect to see another aircraft at that altitude so close to the mountain. There may be search & rescue helicopters there, but that can happen at any altitude, hence keeping visual line of sight of your aircraft. There may also be military fighter jets training in the area at low altitude close to or between the mountains, but if you've checked NOTAM's you will be covered as far as practically possible.
Remember, most aircraft don't know exactly how high they are above ground level, so they have to work with worst case scenario's, i.e. if there's a mountain in the area, they need to be 500ft above that regardless of the surroundings.
Just do a risk assessment (in your head) & you shouldn't have any problems. If you're really concerned, do a written risk assessment to show you're acting responsibly.
