Faulty OFDM module
mike
Hi
I have recently sent my P3A to DJI and is it kepts losing connection to the RC and coming home.
They have replaced the OFDM unit as the cause.  (they said it was unstable)
Symptoms: inside house it would connect to RC .. outside it would take upto 2mins to connect and then the drone would fly for a few minutes, the link to the RC would fail and then the P3A would come back home.
Sorry to sound dumb .. but what does the ODFM unit do ?  and is this a reasonable solution ?
Thanks
Mike
2016-2-25
terrylewis
Flight distance : 3517287 ft
OFDM stands for Orthogonal frequency-division multiplexing
In my terms, this is what Lightbridge uses to communicate between your P3 and the Remote Controller. The OFDM module is the AIR side Lightbridge transmitter/receiver... The RC has similar GROUND side receiver/transmitter. The module is available from the DJI Store
2016-2-25
mike
terrylewis Posted at 2016-2-25 12:59
In my terms, this is what Lightbridg ...
thanks .. so that would be consistent with the problems I have been getting (ie loss of connection between the P3 and the remote)
2016-2-25
terrylewis
mike@perkinsuk. Posted at 2016-2-25 22:19
thanks .. so that would be consistent with the problems I have been getting (ie loss of connection ...
Correct. They replaced the aircraft side -> assuming the RC side tested ok/good...
2016-2-25
fans93402f11
I'm having the same issues as well for my Phantom 3 4k (not pro or advance). I've decided to replace the OFDM module but am having trouble finding that part online. Any help?
2017-1-4
