Donnie
Flight distance : 3636782 ft
Ok is it your videos that are blurry or is it your Photographs? Are you using any additonal filters? Did you Install the UV filter that came standard with I1? Are you using manual settings or Auto ? Are they blurry in the center or all over the picture? Can you Post a video or photographs for an example? ? Try and list your settings with the video also: video size, frame rate, etc. Are you flying in cold weather and the lens could be fogging ? I am not an expert in this field but I can tell you there are some brilliant folks on here who can help you but they are going to want to know a lot more information . If you post some of your video or photo, I am sure someone will chime in.
All the best -donnie
