dobmatt Posted at 2016-3-24 05:42
Ken, the Inspire 1 Pro Release Notes (2016.03.07) says DJI Go iOS should be upgraded to v2.6.0. Is ...
it's not an error, the Pro firmware came out on the 7th and the app was updated on the 16th. Same with Android, it says 2.6.1
But I will make a note and see if the release notes can be changed.
DJI-Ken Posted at 2016-3-23 15:57
it's not an error, the Pro firmware came out on the 7th and the app was updated on the 16th. Same w ...
Thank you, Ken. Everything is changing fast like in Sport mode ... Not sure I can keep up ... Maybe I should set the tablet in Airplane mode and just fly my birds ignoring the world around ...
Help, I've accidentally updated my inspire pro to the x3 version 1.6.00.40, I've tried to fix by upgrading to version 1.4.0.70 which is the latest pro version but only the camera is updating, the aircraft won't budge off version 1.6.00.40 no matter what I try, any ideas? Will it be OK to use in the current setup as I have a job booked in tomorrow, thanks
Don't worry, the latest aircraft is 1.6. The 1.7 firmware update for the Inspire was only for the camera. So if you have a X3, the camera will say 1.7 and the aircraft will say 1.6.
If you have a X5, the camera will say 1.4, and the aircraft 1.6.
Have an Inspire Pro X5. Existing Camera firmware is 1.3.0.60 and aircraft is 1.6.00.40.
However no matter what I do, the new firmware 1.4 will not load. Im doing the usual process,
loading bin file onto card and then card into Inspire however nothing happens. Have tried multiple cards multiple times.
Would appreciate any and all recommendations
Thanks
DJI-Ken Posted at 2016-3-7 20:57
That's how it always was. The inspire1 and Inspire Pro have different version numbers.
If you have ...
DJI Ken,
I have a new Inspire Pro. I have accidentally upgraded the firmware to the X3's version (v.1.6.0.40) rather than the X5 version (v1.4.0.70). What do I do to get the correct version? Can I downgrade and then update? How do I downgrade? Will the version I have installed cause me any problems?
Thanks.
No big deal, go to the about page and see if the camera says 1.4. If not then download the 1.4 firmware for the Pro.
The aircraft version for both Inspires is 1.6, just the X3 camera is 1.7.
DJI-Ken Posted at 2016-4-4 18:24
No big deal, go to the about page and see if the camera says 1.4. If not then download the 1.4 fir ...
Thanks. In that case I didn't accidentally download the incorrect version. I expected the aircraft version to be 1.4. Not very clear for a newbie. Thanks again.
We could know date to include GS Pro in the crystalsky???? I work in photogrammetry and I bought the crystalsky ultra and it bothers me a lot to change the support for the iPad and work with the current GS Pro app. Any information on this subject, would be very grateful for me.
