I’m a new-bie to phantom 2 and I've been attempting to update the firmware but I just cannot get the Naza to connect to the USB...or I should say the assistant.
First off, I must say that the wiring configuration on the P2 Naza is totally different than what I see in a phantom 1.
I have checked lots to You-Tube videos on the Phantom 2 Naza wiring and all looks correct.
I have several 5.8 controllers that all bind to the P2 and allow full control.
All the ESCs are connected and the P2 will fly...but a little erratic...
I do not have any FPV camera/gimbal hooked up so there are several plugs on the main PCB that are not being used at the time.
I do have the latest assistant installed on my PC and I can get my other P1's to connect just fine.... but not he P2.
I have taken the P1 Naza and connected the P2 USB plug and the P1 Naza connects fine so the USB connector/wires in the P2 seems OK.
(I do have a new PCB and Naza in the P2) Almost forgot... Im using Windows Xp...
What am I missing? |
