Donnie
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
Flight distance : 3636782 ft
Here are some tips for you, In case you forgot anything. This will bring you up to speed on the update process. I personally think you should update but it is up to you. Just dont Jump updates! Take one minute to read, might save you some grief.
- After 1.3 the update FOR the Transmitter is NOT through the SD Card it is through The DJI go app and WI-FI connection.
-Always update the aircraft first.
-Make sure you download the proper firmware. If you have the Pro make sure not downloading for the Advanced or standard. Double check!
-Make sure you only download the Bin File to the FRESH FORMATTED SD CARD Root Directory.
-Make sure transmitter is NOT on when downloading Firmware to aircraft ( VERY IMPORTANT)
-When installing SD with fresh firmware to the Aircraft, make sure it is off. Then turn on aircraft, the firmware will then begin load.
-YOU CANT JUMP FROM 1.4 TO 1.6. You must stair step 1.3 to 1.4 to 1.5 to 1.6
-All the firmware numbers for the RC - aircraft- Go App - Camera WONT BE THE SAME. For example the current aircraft firmware is 1.6.0.40 but the RC Firmware is 1.5.70. A LOT OF FOLKS GET CONFUSED ON THIS (Including Yours Truly when first starting out.)
-Sometimes only the aircraft gets an update and not RC Transmitter Read the pdf on the downloads page so you know what’s going on for example 1.6.0.40 is only for the aircraft and batteries.
-Make sure to read what each update is effecting. For example 1.6.0.4.0 will require each battery to be updated as well. Keep Informed.
-Macs’ sometimes do not format SD cards well. When Formatting Success is in doubt FORMAT ON THE AIRCRAFT, go to camera settings on dji go app , open the tool icon , on bottom is Format SD card option.
-Updates sometimes take a while, wait for the tone to change to d-dd d-dd d-dd d-dd d-dd d-dd d-dd or the solid green light even better.
-If you hear a long dddddddddddddddddddddddddddddddddddddddddddddd it has failed.
-updating is not an option for just the aircraft, IF there is also an update at that time for the Transmitter you MUST do it.
-To find out your current Firmware: Make sure The Aircraft, Transmitter, and GO-APP are all on. Now go to the “Main Video Flight Screen” , Tap the right hand corner for “ Settings” on the Very Left Bottom of tab icons you will see - - - this is the “ General Settings Go to “About “ Here you will find current Firmware on each device. If you only see the “App Version it is because you did not turn everything on like I told Yawl’. : )
-Updates for the Phantom Standard are Only Done through GO-App and Wi-Fi, no SD Firmware to upload.
- You cant Rollback the Battery Firmware once installed. Once Installed that’s it. ( Battery Only)
-When doing a Rollback, confirm the Current firmware on the Aircraft and then Rollback Firmware in Order. NO JUMPING ALLOWED
Hope this helps, all the best - donnie
