Donnie
Flight distance : 3636782 ft
First you must enable "Mult Flight mode" in the DJI go app under MC (aircraft) settings. Then it is kind of silly but you must be in the air to acces these settings. Get in a Hover about 40 feet high (At least) and out a bout 100 feet in front of you, then flip the toggle from GPS mode"P" down to "F" mode. Here you will have access to POI, Way-points, Follow Me . Now follow me can only be used if you have active gps on your device. And Way-points must be flown first and then recorded, this can be used for future use. To close out of "F" mode simply toggle back to "P" it just takes some time using these settings. You can not access them unless you are in the air "DUMB". They say they will change it in the future.
Hope this helps,- donnie domaldjames1990@gmail.com if you have other questions and cant find then here, i will try to help |
