Kneepuck
Flight distance : 275105 ft
Some clarification here; The P4, like the P3, only has limited pan movement. You have to turn the drone to turn the camera. The amount of movement the camera gimbal has from side to side is just for stabilization. If it would pan, you would end up with nice close up shots of your landing gear. The tilt function has motion, not the pan. That being said, when using the Litchi waypoint function, you can specify the direction of the camera for each waypoint |
