Donnie
Flight distance : 3636782 ft
When you are starting the system, after you install the GO App, it should ask for e Mail address etc. If you are already registered .
You will do the second P3P the same as the first. Since the GO APP is already registered it may not even ask you .
When I went from the P3P to the Inspire, it think it just asked to confirm my e mail. The bottom line is do not start doing updates until you have gone through the basics of your system. I always suggest to fly with what you are given ( firmware ) to make sure everything works and then do any updates.
And yes I would delete the old Go App and start with fresh Install, this way your settings cant get mixed up . ( dont think they would but I would just start fresh )
****The reason I posted that is because new pilots who had old DJI systems started updating before they registered and it screws up the system preventiing motors from starting. So I always advise to start from the very beginning , just like the original system and to even test fly with what version is given. This way you wont get the dreaeded lock out.
donnie
Donnie
