Donnie
Flight distance : 3636782 ft
Double check you're Image Transmission Settings, perhaps move the slider down to a lower bit rate. Also Make sure you are not in custom mode where the signal had no where to jump to . Also" Enable the Hardware Decoding" in General settings to take some of the stress off the processor. Make sure to clear the video cache as well, this might be slowing things down as well. Of course No apps running in the background. last thing, I would do the 32 channel "Upgrade" some call it a hack, but that is a divisive term, it helped my video immensely. I think you should go to the APPLE I-pads as well, there was a fellow on you tube who tested all types of devices and the APPLE air had the least amount of lag. You now have a high end machine, you are going to have to up your device as well i think to maximize it's effectiveness.
I know you probably know most of this but you may have just missed one and it should help.
all the best to you and yours - donnie |
