Daroga
Flight distance : 3517287 ft
metalbits Posted at 2017-4-2 02:06
hi and thanks , im afraid i cant tell you any info and it states its dsconnetcted . the pink/purple light , i turn it on and the controls led blinks red twice and then turns purple . i lent it to a friend and he put it in slave mode for his i1 and then returned it . ive tried the 3/4 reset trick and also tried putting firmware on a usb stick still no joy
Metalbits,
As Donnie suggests, we need to know some additional info...
1) Leave Aircraft OFF
2) Leave Master RC OFF
3) Connect USB cable to Slave and your Mobile device (and tell us what you're using [Android or iOS] an the GO App version...
4) Turn Slave RC ON & launch the GO App.
5) Ensure the correct Inspire Model is selected and launch the main Equipment screen.
6) On this screen there's a Graduation Cap icon in the upper corner [The Academy icon].
7) Press and hold this icon for at least 10 seconds.... (seems like forever) and the RC firmware upgrade/downgrade page should appear. If it doesn't appear hold the Graduation Cap longer ;-) -> It will look somewhat like this screenshot:
8) Tell us what RC version it shows. Don't worry about it saying disconnected - it should say disconnected.
9) In the GO App, select General Settings and scroll to the bottom.... Select About. What does it show?
10) In the GO App, select Remote Controller Setting and either take a screenshot or post what you see here. It should look like this:
The slave RC should communicate with the GO App when only the slave RC is powered on. The RC leds you are seeing are normal for your situation.
If we can get this far, then let us know and we then get your firmware synced to the correct versions and then link your slave to the master...
Good luck,
Terry
