hummingbird.uav
Flight distance : 27489951 ft
Sadly only one aircraft will bind with the controller at a time. I can bind the P4 controller to the P3P aircraft but switching to the P4 aircraft is not possible without rebinding. The selector at the opening of the Go App does not work once the Tx is powered on, it defaults to the last aircraft bound to the Tx. Doing a rebind will switch the app display to the correct configuration of the newly bound aircraft. ie turn on app with P4 display, bind to P3P and the display & commands change to P3P and vice versa.
My FrSky Tx would bind to any number of receivers once it powered up and I selected which model I wanted to use. Go App should work like this too.
(All hardware is loaded with the lates firmware versions)
