Prop question from a Newbie
611 3 2016-3-22
ba0201
Flight distance : 251407 ft
Hello --
When do you change props?  Do they 'wear out'? Assuming there isn't any physical damage, is there any rationale to change them?
TIA,
-- Brian
2016-3-22
boxerman
Flight distance : 39695 ft
Eventually they'll get junk on them - you'd be amazed at the bugs the props hit, honestly.  You can clean all that off, but if it whacks the grass or twigs, you might actually knick them - just do an inspection and if you have knicks in the props, replace them.  I fly with the same set until I get a scrape or knick.  Oh and from some extensive comparison test I've seen, the original DJI props are the absolute best for efficiency, thrust, and economy.
2016-3-22
DJI-Tim
Not really, there will be no damage unless you crash the drone
2016-3-23
DJI-Tim
boxerman Posted at 2016-3-23 14:24
Eventually they'll get junk on them - you'd be amazed at the bugs the props hit, honestly.  You can  ...
Correct! Also efficiency  depends on motors, i'll post an article about it very soon
2016-3-23
