fhagan02
Flight distance : 1854908 ft
You'll need to recalibrate your controller (The Control Sticks, X1 and X2 controls). X1 is the dedicated switch that moves your gimgals tilt. This is the one that's giving you the issue I suspect. You should really do this after any and every firmware update. Gets eveything "back in sync."
Plug your Phantom 2 up to your computer with the micro usb. Turn the Phantom on.
First Launch the RC Assistant Software and calibrate the controller. Calibrate The Sticks AND the X1 (gimbal tilt) and X2(Home lock, Course lock, Off) controls before clicking "finished". NOTE: There's only one button to calibrate all four. e.g.: (2) sticks + (1) X1 and (1) X2
Second: Launch the PT2 Assistant Software and calibrate the controller again. NOTE: The sticks have thier own separate calibrate button as do the X1 and X2 in this application. Do both of these calibrations within the PT2 Assistant Software.
After this the gimbal should respond the correct way to your controller tilt wheel OR tilt lever depending on which controller you own.
FYI: If you're running the latest gimbal firmware the camera will always positions itself at about 45º after initializing and doing it's warm up dance. This is normal. After these calibrations you'll be able to use the tilt wheel to reposition the tilt as you like before you start flying/filming.
