Geebax
'1: Why does it go from 100% (indicated) reception to nothing - why did it not go to 75% -> 50% -> 25% etc....'
Because it is a digital transmission, look up the term Cliff Effect on Google. When radio systems transmit digital information, there are errtor correction elements in the transmission that fix up errors on the fly, but when the signal finally gets too weak, the correction stops, and the signal loss is like 'it fell off a cliff'. Therefore there is no gradual fade-off of the signal.
'2: why when no reception (apparent disconnect on RC and LiveView) can i still fly it back'
The Phantom uses two completely different radio systems, one for control and the other for the Lightbridge FPV system. The FPV system is less tolerant of signal loss and usually fails first, hence you still have the other radio system to control the aircraft.
'3: why when flying it back and closer to "home" does it then RTH'
Possibly because your battery got down to the RTH threshhold level.
