endotherm
Flight distance : 503241 ft
Because the forum is global, sometimes you need to wait 24 hours or so for a reply...
I used the data uploaded by the OP to Healthy Drones, and downloaded the flight path/signal strength as a .kml file. There is a link on Healthy Drones to do that. .kml files can be opened in Google Earth (I use Google Earth Pro). You will get a piece of 3D "spaghetti" on the map, and you can scroll around the map and view it from any angle. There are also some 3D buildings represented on some of the images, these are also contained in Google Earth and can be turned on or off as an option. Not all buildings are available as models, you will be luckier seeing them at the center of cities where most buildings will have been rendered, otherwise it may be limited to landmarks and significant buildings.
The images I posted were just screengrabs once I had a descriptive view in Google Earth.
