Thread for Newbies
312603 919 2014-9-27
DJI Susan
djiuser_KIINGbC3vLGV Posted at 10-5 17:55
Sorry, I’m new here so if this post is in the wrong place forgive me. It would not let me post under ‘service’. I’ve noticed that many folks seem to have an issue similar to mind. I have a mini 2 and have had maybe 5 short flights.
I’m having ‘gimbal motor overload’ (I believe that’s the right phrasing). I tried some of the recommended fixes (make sure I have the newest firmware, do all the calibrations, etc). I noticed when running through the calibrations that the gimbal and bottom of the drone felt very hot.
Hi there, may we double confirm if the error persists after the gimbal calibration?
Please check if the error pops up when the drone is not in flight. If so, you may need to send the drone back so we can check it further. You can click https://www.dji.com/us/service/repair to start an online repair case.
If the error only exists during the flight, if the prompt only appears in Sport mode, a possible reason might be that the stick is pushed away too far from the center position and exceeds the gimbal limit. Gently pushing the stick will solve some issues.
2. If this issue occurs when the aircraft is flying in N-mode or T-mode, please kindly check the info below:
1) Check whether a third-party filter is mounted. The Mini 2 gimbal does not support any third-party filter accessories.
2) Ensure that the gimbal cover is removed before powered on.
3) Place the aircraft on the ground, and then check if the ground is uneven, or if any foreign objects are obstructing the gimbal.
If the issue persists, you can also send the drone in. Thank you.
2022-10-6
djiuser_oQk5ojNYtf9S
Hello, I’m new to dji forum, but was wondering if there is anyway to get a coupon code reactivated? I was in the hospital this weekend and didn’t realize that I had a coupon for the dji store.. it’s unfortunate but I would really like to use it if possible.
2022-10-12
DJI Thor
Flight distance : 13602 ft
djiuser_oQk5ojNYtf9S Posted at 10-12 23:24
Hi, there. Sorry for your inconvenience. Could you please tell us the coupon code via PM for our further checks?
2022-10-13
DJI Thor Posted at 10-13 04:26
Hi, I have sent you PM regarding the issue.
2022-10-18
djiuser_oQk5ojNYtf9S Posted at 10-18 21:07
Hi there, may I ask where you get the coupon from? Could you please provide us with a screenshot for a further check? Please note to cover the coupon code and then post it publicly.
2022-10-19
Rebecca DJI
Flight distance : 459 ft
Mini 3 pro, rapidly flying to one side during auto take off. Not constantly but 2 out of 4 times. Pre flight checks done and RC states ready to fly. Please advise?
2023-2-9
Rebecca DJI Posted at 2-9 04:57
Hi there, could you please provide us with a video showing this issue for our further confirmation? You can upload the video to Google Drive or Dropbox and send us the link here.
2023-2-9
djiuser_s8cME45hVqHx
There is no settings on the homepage to change my username.
2023-2-15
DJI Wanda
djiuser_s8cME45hVqHx Posted at 2-15 05:34
Hello, there. Sorry for the inconvenience. You can follow the path to edit the username:
DJI FLY APP- Profile - tap area where the username is at - edit
2023-2-16
DJI Wanda Posted at 2-16 03:05
I have the dji go app and have my username changed to Steveo2437 and go to the forum from within the app but it still shows this name. Do i need that specific app it have it integrate the new username?
2023-2-16
djiuser_s8cME45hVqHx Posted at 2-16 05:04
Sorry for the confusion caused. If you want to change the username of your forum account, you can go to your personal homepage and then set your username.
2023-2-17
Steveo2437
DJI Mindy Posted at 2-17 00:03
[view_image]
I finnaly got it to work, on mobile settings doesnt show up anywhere.  I clicked display as desktop page and that worked.
2023-2-17
Steveo2437 Posted at 2-17 07:44
Glad to know you got it resolved. If there is anything else we can help you with, please feel free to contact us.
2023-2-18
djiuser_cfUhy0If3N1u
Flight distance : 61650 ft
Indonesia
Hello, we purchased a dgi mini pro 3 in Australia, and activated it 1 week ago , we are currently overseas and require some repair work. Gimble is working and camera is working it just won’t fly . Will that void the warranty?
2023-3-9
djiuser_cfUhy0If3N1u Posted at 3-9 19:44
Hi there, please note that DJI does not provide global warranty, customers can obtain warranty service in the region of the product version. However, depending on part availability, customers can obtain cross-regional repair service at an additional charge.
2023-3-9
djiuser_3BiLccryEoHk
Flight distance : 349711 ft
Brunei
i  lost my Avata in the ocean, as Avata suddenly shut down. can i do a refund?
2023-4-6
djiuser_3BiLccryEoHk Posted at 4-6 17:32
Hi there, we are sorry to know about the accident. We recommend that you contact our support team and start a case through the link below. Our team will provide a corresponding solution. If there is a doubt about the accident, data analysis can also be applied as long as the drone is within the warranty period. http://www.dji.com/support
2023-4-6
taktuntuang91
Cambodia
Wanted to jump in and say hello and I’m new to the forms and on top of that just received my FC40 today. Upon opening the box to my surprise there was no kind of manuals or directions of any kind to help in putting this quad together , so glad I did my home work by checking this and you tube out and d/l  the manual from here…
Wanted the vision 2 but after researching and getting this I’m one happy man and this FC40 fly’s so easy and good…all I can say is WOW what took me so long to get into quads and getting DLI Phantom FC40 hoping these are durable and get many hours of flight time in……
2023-4-14
djiuser_84p8DIbDvrA3
Flight distance : 4272 ft
Argentina
Alguien me podria decir como activar los sensores del dji mini 4 pro?
2023-10-15
DJI Wanda
djiuser_84p8DIbDvrA3 Posted at 10-15 19:23
Hello, there. Sorry for the inconvenience. May we know why do you want to activate the sensor of the DJI Mini 4 Pro?
2023-10-16
djiuser_UGkiAcLoG3nm
Hello everyone! I have a DJI Mavic Pro 3 and I am hoping to keep learning and continue to hone my skills.
2023-11-22
wave5 Posted at 2014-11-9 14:40
Hi All, I'm somewhat of a newbie of a Phantom 2. I've had it for a year but not much flight time. I have discovered that if I receive a call or text while flying, it stops the camera. Am I doing something wrong? Thanks in advance!
I would recommend putting your phone in Do Not Disturb mode while flying to limit distractions!
2023-11-22
djiuser_n6ukjIDcNrtl
activation test
2023-11-28
fans126b4cce
Chile
Hola, soy nuevo en este foro. Tengo un Inspire 1 V2, todo estaba bien hasta que la aplicación DJI Go en mi iPad pidió actualizar, sin embargo ahora no puedo grabar ni tomar fotografías, solo puedo volar... a ciegas. ¿Cómo puedo obtener la aplicación antigua para IOS?
Hello, I am new in this forum. I have an Inspire 1 V2, everything was fine until the DJI Go app on my iPad asked to update, however now it can't record or take pictures, I can only fly... blindly. How can I get the old app for IOS
2023-12-14
fans126b4cce
Chile
2023-12-14
The Pain
Flight distance : 177 ft
Mini Pro 4.  Activations test
1-14 15:14
MartinKirk
Denmark
I cant start a new thread .. so i'm replying here just to test.
maybe i need to start like htis ?
2-5 11:40
MartinKirk Posted at 2-5 11:40
New users need to acquire 20 points to unlock this ability to make a new thread. (See points rules through the link below.) https://forum.dji.com/forum.php?mod=viewthread&tid=71515
2-5 22:54
MartinKirk
Denmark
DJI Mindy Posted at 2-5 22:54
Ohh thanks for pointing that out.
I totally missed the notice about the points (its grayed out)
I read most of the rules though but somehow missed that part.
2-7 04:25
MartinKirk Posted at 2-7 04:25
You're welcome. Should you have any further inquiries, please feel free to contact us.
2-7 17:32
LUXO-ARG
Argentina
hola, soy de argentina!
3-22 12:49
DJI Susan
LUXO-ARG Posted at 3-22 12:49
Hi there, could you please tell me the exact issue you encountered?
3-31 20:11
The Harmory
Hello,
Since I am not yet allowed to open a new thread for my question, I will ask it here:
Is it safe to charge the accu's for the Avata (2) with a 120w charger?
4-16 00:37
DJI Susan
The Harmory Posted at 4-16 00:37
Hello,
Hello.120W can charge Avata 2. Because USB charging itself has protocols. The two communicate when charging. Your charger is 120W, but the maximum power of the fuselage is 30W. After communication, the charging head will charge the fuselage with a power of 30W.
4-16 01:21
The Harmory
DJI Susan Posted at 4-16 01:21
Thank you very much for the response Susan!
4-16 02:04
DJI Susan
The Harmory Posted at 4-16 02:04
You're very welcome! We are glad we could assist you. If you have any more questions or need further help, feel free to ask.
4-16 02:08
HavocDante
Flight distance : 20883 ft
Thank you for the welcoming
4-17 15:19
miniseries542
How can I post on the DJI forum? For some reason, even though I have already created and activated my account, it wont give me access. Do I need a different browser than chrome?
5-1 16:49
miniseries542 Posted at 5-1 16:49
Hi there, please note that the New Group cannot post threads, you can refer to: https://forum.dji.com/forum.php? ... mp;page=1#pid623201
5-1 23:49
minifan542
Thank you for this information! How can I get more than 40 points? I have been trying to gain more points recently.
1 hour ago
